First you made a pseudo gated clock with a different "clock"which is bad. I suggest you to resynchronize with your system clock (IN_CLK).
Even if it makes sense in VHDL, It is smarter using a whole unique system clock (IN_CLK) in this case.
You can correct this with :
ext_write : process(IN_RESETn, IN_CLK)
begin
if IN_RESETn = '0' then
REG_R00_HORIZ_TOTAL_7_0 <= b"0010_1111";
elsif falling_edge (IN_CLK) then
if falling_edge(IN_E) and IN_CSn='0' and IN_RW='0' then --Grab data from data bus and program into indexed register.
case REG_INDEX_ADDR_4_0 is --Use Reg Index to write D0-7 to reg
when INDEX_HT => REG_R00_HORIZ_TOTAL_7_0 <= IO_D_7_0;
etc
Secondly,
LIBRARY ieee;
USE ieee.STD_LOGIC_1164.all; -- 'Z' 'X' '1' '0' 'W' 'U' 'L' 'H' '-'
USE ieee.numeric_std.all; -- UNSIGNED, SIGNED, + - * / mod
