12 years agonumber of M9K
I have a meory with size 8704*32. Iw ant to implement it on Cyclone 3 device. Megawizard shows that I need 31 M9K+ some LUts for this memory. Fitter fails and asks for 34 M9K. Any idea?
I have a question on similar lines.. I have a memory with the configuration : 32 (width)x512 (depth). The sysnthesis shows that 12 instances of block RAM were inferred. The fitter report shows that: M9Ks used are : 8 Total block memory bits = 6,144 / 5,621,760 ( < 1 % ) Total block memory implementation bits = 73,728 / 5,621,760 ( 1 % ) I have 2 questions. 1) Why are 8 M9Ks used ? So my total memory size is 512 * 32 = 16384.. which can be accommodated in just 2 M9K s right? I don't understand how Quartus is mapping the block RAMs. 2) What is the difference between Total block memory bits and Total block memory implementation bits ? Looking forward to your reply. Thank you.
