15 years agonow able to simulate altpll using vwf file
hi,
i am new to this, and trying to simulate altpll with input clock frequency of 27Mhz, however, when i set that input clock of 37037 ps, i am not able to lock it, below is my altpll setting, did i do anything wrong? it seem to be working fine when i program it into the altera Cyclone II DEII board. i have attached my vwf output, can someone help me on this.. thanks i am seeing below warning during compilation Info: System task: Warning : Input clock freq. is not within VCO range. PLL may not lock below is the module module VGA_Audio_PLL (
areset,
inclk0,
c0,
c1,
c2);
input areset;
input inclk0;
output c0;
output c1;
output c2;
wire sub_wire0;
wire sub_wire6 = 1'h0;
wire sub_wire3 = sub_wire0;
wire sub_wire2 = sub_wire0;
wire sub_wire1 = sub_wire0;
wire c0 = sub_wire1;
wire c1 = sub_wire2;
wire c2 = sub_wire3;
wire sub_wire4 = inclk0;
wire sub_wire5 = {sub_wire6, sub_wire4};
altpll altpll_component (
.inclk (sub_wire5),
.areset (areset),
.clk (sub_wire0),
.activeclock (),
.clkbad (),
.clkena ({6{1'b1}}),
.clkloss (),
.clkswitch (1'b0),
.configupdate (1'b0),
.enable0 (),
.enable1 (),
.extclk (),
.extclkena ({4{1'b1}}),
.fbin (1'b1),
.fbmimicbidir (),
.fbout (),
.locked (),
.pfdena (1'b1),
.phasecounterselect ({4{1'b1}}),
.phasedone (),
.phasestep (1'b1),
.phaseupdown (1'b1),
.pllena (1'b1),
.scanaclr (1'b0),
.scanclk (1'b0),
.scanclkena (1'b1),
.scandata (1'b0),
.scandataout (),
.scandone (),
.scanread (1'b0),
.scanwrite (1'b0),
.sclkout0 (),
.sclkout1 (),
.vcooverrange (),
.vcounderrange ());
defparam
altpll_component.clk0_divide_by = 15,
altpll_component.clk0_duty_cycle = 50,
altpll_component.clk0_multiply_by = 14,
altpll_component.clk0_phase_shift = "0",
altpll_component.clk1_divide_by = 3,
altpll_component.clk1_duty_cycle = 50,
altpll_component.clk1_multiply_by = 2,
altpll_component.clk1_phase_shift = "0",
altpll_component.clk2_divide_by = 15,
altpll_component.clk2_duty_cycle = 50,
altpll_component.clk2_multiply_by = 14,
altpll_component.clk2_phase_shift = "-9921",
altpll_component.compensate_clock = "CLK0",
altpll_component.inclk0_input_frequency = 37037,
altpll_component.intended_device_family = "Cyclone II",
altpll_component.lpm_type = "altpll",
altpll_component.operation_mode = "NORMAL",
