VSavi3
3 years agoNot able to do fitting design with Quartus 22.1
Hi, I am able to fit the attached design with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition. However, I can fit the design with ease in Version 19.1.0 Build 670 09/22/2019 SJ Standard ...
Nurina
3 years agoHi,
Maybe we can work with the .qsf file and all the *.rpt files for both versions as a start.
Would it be possible to encrypt the source files? It would be difficult for us to provide support without the full design because there are many factors affecting the problem you're facing, such as .qsf settings, RTL code, logic lock assignments, etc. So with your full design we'd have the correct settings and environment required to reproduce your problem, hence we're able to make the correct comparison.
Nurina
- VSavi33 years ago
Hi Nurina,
I here with attached qsf and report files of both runs.
Let me know if there is some settings in 22.1 needs to be changed.
Vikram
