11 years ago --- Quote Start --- I just found out the problem. It was related to the toplevel entity name. In VHDL is was calmar_top and in the quartus setting file Calmar_top. Apparently this setting worked in other version of quartus for the Node Finder but in the Version 13.1 there is a problem with that. Therefore Nodefinder couldn't find any nodes. Cheers --- Quote End --- Thank you so much!!!! You've just solved my problem!)
