14 years ago --- Quote Start --- Weird. Fire up the RTL Netlist viewer and try to find any place where emi_addr[0] drives a flip-flop's clock pin or so. Compilations are driven by a random seed, so you can expect small changes from one to the other. Is it negative setup or hold slack? --- Quote End --- dear,rbugalho RTL view,see the attachment.the address signal is fed to the comparator at the first level logic. it's holdup slack now,and sometimes a setup slack report errors. the error node(hold up ) : --- Quote Start --- network|IP|DATA_Control|Over_IP|OP_1|ONE|PTS|LAST_OUT|FIFO_TX|dcfifo_mixed_widths:dcfifo_mixed_widths_component|dcfifo_07i1:auto_generated|delayed_wrptr_g[7] --- Quote End ---
