12 years ago
No feasible entries for subprogram “CONV_INTEGER”
I have implemented a simple adder component with two inputs and one output.
port ( a,b : in std_logic_vector(31 downto 0);
r : out std_logic_vector(31 downto 0)
I created a test bench in order to test this component. Then I modified this test bench in order to read the inputs from a text file and in order to write the results to a text file. Currently inputs must be binary strings; similarly, the output is written as a binary string.
Now I would improve this test bench in order to read inputs as integer value from text file. I was able to make this change successfully. But I would also like the output to be written as an integer: in this case, the compiler reports an error on a line of the following source code.
architecture tb4 of tb4_adderbehav is
component adderbehav is
end component;
signal a,b : std_logic_vector(31 downto 0);
signal r : std_logic_vector(31 downto 0);
begin
dut: adderbehav port map (a,b,r);
process
variable tbinputs, tboutput : line;
variable va, vb, vr : integer;
file data_file : text;
file result_file : text;
begin
file_open(data_file,"dati_int.txt",read_mode);
file_open(result_file,"risultati_int.txt",write_mode);
while not endfile(data_file) loop
readline(data_file,tbinputs); read(tbinputs,va); read(tbinputs,vb);
a <= conv_std_logic_vector(va, a'length);
b <= conv_std_logic_vector(vb, b'length);
wait for 10 ns;
--vr := conv_integer(r); -- error: no feasible entries for subprogram "conv_integer"
--write(tboutput,vr);
write(tboutput,r);
writeline(result_file,tboutput);
end loop;
file_close(data_file);
file_close(result_file);
wait;
end process;
end tb4;
Why does the error occur in the source code shown above?
In the source code I have included the following libraries:
- ieee.std_logic_1164.all;
- ieee.std_logic_textio.all;
- ieee.std_logic_arith.all;
- ieee.numeric_std.all;
- std.textio.all;
Thank you in advance for any support!
1 Reply
    The problem is that you didnt include the std_logic_signed or std_logic_unsigned library (you cannot add both)
    But just as a comment on the same theme - you shouldnt be using these libraries (and therefore conv_integer function) as it is not standard VHDL. You have also included both std_logic_arith and numeric_std which have conflicts, and so std_logic_arith should be removed (again, a non-standard library).
    Then, to convert to an integer:
    vr := to_integer( unsigned(R) );
    or
    vr := to_integer( signed(R) );
    if you need a signed version.
    The problem with std_logic_(un)signed is that you are limited to signed OR unsigned arithmatic in an entity. Numeric std defines both unsigned and signed types and therefor allows you to do both.
    PS> You should remove the conv_std_logic_vector function too. Replace with:
    B <= std_logic_vector( to_unsigned(vb, B'length) );
    Or to minimuse on the type conversions, just use an integer on your ports. You dont have to use std_logic_vector everywhere.
