12 years agoNo CFI table found at address 0x04000000
Hello everyone, I'm trying to execute bit on tutorial "My first tutorial nios II", in which I use System Building and SOPC. In SOPC add to my system also Flash memory interface (CFI). My problem is that when I go to use the flash programmer in NIOS II IDE, the console displays the following message:
# / bin / sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten When the flash programmer options change.# cd C :/ Users/Raffaele/Desktop/my_first_niosii/software/hello_world_0/Debug # Creating. Flash file for the project "$ SOPC_KIT_NIOS2/bin/elf2flash" - base = 0x04000000 - end = 0x7ffffff - reset = 0x4000 020 - input = "hello_world_0.elf" - output = "cfi_flash_0.flash" - boot = "C :/ alters / 1 1.0sp1/ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec " # Programming flash with the project "$ SOPC_KIT_NIOS2/bin/nios2-flash-programmer" - base = 0x04000000 "cfi_flash_0.fla sh " Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK No CFI table found at address 0x04000000 Leaving target processor paused I tried to perform a variety of ways but to no avail. how can I solve my problem? P.S: I use a NIOS II \ \ e.
