17 years ago
No CFI table found at address 0x00000000
My SOPC has cfi_flash,and its base address is 0x0.But when I used the Flash Programmer in Nios IDE, it paused with
Leaving target processor paused
It could't find the cfi_flash? I checked in Nios commend shell,also the problem.
what's the matter?
    Hi
    I tried like this
    nios2-flash-programmer -g ro.flashs_ext_flash.flash --base=0x8000000
    using cable "USB-Blaster [USB-0]", device 1, instance 0x00
    Resetting and pausing target processor : OK
    Checksum took 0.0z
    erase not required
    Program failed at offset 10001E
    Error: Error code: 4 for command: nios2-flash-programmer "D:/web/webserver1/board_update_portal/software/web_server270813_bsp/flash/ro.flashfs_ext_flash.flash" --base=0x8000000 --sidp=0x8024E0 --id=0x0 --timestamp=1377500456 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose.
    Are you sure of your base address ?
    You have double extension on your flash file, maybe that cause problem
    --- Quote Start ---
    --- Quote End ---
    Maybe a watchdog
    Maybe timing problems (mostly)
    I am trying to execute example code only what ever i got from altera cyclone III development board examples
    I installed the cyclone III fpga development kit
    In that i have the board update portal.If i want to execute that file it is showing errors
    In my cyclone III development board i am using S29GL512N flash
    I ran into the same problem yesterday. I had a qsys system that was implemented and running, but I needed to add a Flash component for booting on power-up. After adding the Flash components in the System Contents view, I generated and compiled my design. Using the command line to program the device, I used these commands in a batch file:
    nios2_command_shell.sh sof2flash --input=top_module.sof --output=flash_hw.flash --offset=0x20C0000 --pfl --optionbit=0x00030000 --programmingmode=PS
    nios2_command_shell.sh nios2-flash-programmer --base=0x0 flash_hw.flash
    The first command worked, but the programmer (2nd command) gave me the error ==> No CFI table found at address 0x00000000
    I solved the problem because I realized I did not attached the data_master of the Nios to my avalon memory mapped slave port of the instanced External Flash. In fact, I only had the instruction master connected.
    See the attached image for my solution. Hope this helps.
    Hi all,
    I've a similar problem due to a migration from SOPC design to Qsys, on Quartus 12.1 sp1.
    Basically, it's a Nios2 linked to sram(32bit addr), f-ram(16bit addr.) and a flash cfi compliance (16bit addr.).
    Now, I no longer able to download my firmware on cfi flash via nios2-flash-programmer ( No CFI table found at address... ).
    In the Qsys design, I have one Generic Tri-State Controller for every memory device. They are connected to a Tri-State Conduit Pin Sharer and this is connected to Tri-State Conduit Bridge.
    I'm able to read/write data from/to sram and fram and then I'm pretty sure the bus is ok.
    Via oscilloscope, I checked that signals timings are ok. I noticed that, while in SOPC the flash memory access is @ 16bit, now in Qsys, the access is @ 32bit, but I don't thing this is the problem.
    Any, ideas?
    Thanks in advance,
    Rino
    p.s.
    Sorry for my english
    Hi, did you configure your CFI FLASH as a 16bit wide ?
    It becomes hard to manually configure a CFI FLASH in QSYS (in version 12.0SP1). The documentation are incomplete, split. bad point from altera.
    yes. But I found the mistake even though I didn't completly understand the solution.
    The flash is a 16bit data width, density 1Gbit then 26bit of addressing lines.
    In the electrical scheme his address pin A00 is connected to the pin 01 of the address bus, A01 to pin02, A02 to pin 03 and so on.
    Originally, I've done in this way:
    --> in Qsys, when I instantiated the flash controller, I declared, in the generic tri-state controller, addr width = 26 and data width = 16.
    Then I obtained an Out_addr : out std_logic_vector(25 downto 0).
    --> On the top level, I wrote: Out_addr => PRIMARY_BUS_ADDR(26 down to 1), where PRIMARY_BUS_ADDR is a std_logic_vector(26 downto 0).
    I thought it was ok, but I wasn't able to access to the flash memory.
    After many tests, I declared:
    --> in Qsys, in the generic tri-state controller, addr width = 27 , then I obtain an Out_addr : out std_logic_vector(26 downto 0)
    --> on top level, Out_addr => PRIMARY_BUS_ADDR.
    Now I can read/write the flash via nios2-flash-programmer and my system works fine...even though I didn't understand because in the first way it does not work.
    Bye,
    Rino
