12 years agoAre you sure of your base address ?
You have double extension on your flash file, maybe that cause problem --- Quote Start --- nios2-flash-programmer "D:/web/webserver1/board_update_portal/software/web_server270813_bsp/flash/ro.flashfs_ext_flash.flash" --- Quote End --- Maybe a watchdog Maybe timing problems (mostly) Regards
