13 years ago --- Quote Start --- Thank you , Thank you , Thank you, Thank you. 4 days trying to debug this problem, 4 days, and your post saved my A**. It works now. Thank you again. Do you know why signals defined as inout wouldn't work with intermediate signals like this ? Edited to add this is for : gmpstr --- Quote End --- I am facing this same issue Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x111010B8: verified Info: No CFI table found at address 0x10800000 Info: Leaving target processor paused Error: Error code: 8 for command: nios2-flash-programmer "E:/Nios_Flash/sys1/software/gui_bsp/flash/gui_cfi_flash_0.flash" --base=0x10800000 --sidp=0x111010B8 --id=0x0 --timestamp=1368512084 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program please explain me what you have done to fix this Bug ? RD asickrishna
