Altera_ForumHonored Contributor18 years agoNo CFI table found at address 0x00000000 My SOPC has cfi_flash,and its base address is 0x0.But when I used the Flash Programmer in Nios IDE, it paused with No CFI table found at address 0x00000000 Leaving target processor paused ...Show More
Altera_ForumHonored Contributor18 years agoYou can try the memory test to see if your flash controller is working properly or not.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
