Julien's avatar
Julien
8 years ago
[NIOS2 SBT, Ubuntu 16.04] version 18.0 segmentation Faults at launch, while 17.0 is OK.
I installed Quartus Lite 18.0 successfully on Ubuntu 16.04, and can use Quartus just fine. But when I try to launch the NIOS2 Eclipse IDE from the "nios2_command_shell", I get a Segmentation Fault.
Trying the exact same test with version 17.0 of QuartusLite works fine, the NIOS eclipse IDE starts correctly
Is there any specific thing I could check to understand why 18.0 segfaults, and fix the issue ?
Thank you,
  • Julien's avatar
    Julien
    I recently upgraded to Ubuntu 18.04, and the problem no longer exists, both Quartus and eclipse-nios2 can be launched without issue now. There must have been some kind of library version incompatibility earlier when I was using Ubuntu 16.04.
    Thank you, no further action needed as far as I am concerned.
  • Ahmed_H_Intel1's avatar
    Ahmed_H_Intel1
    Hi Julien,
    This is weird it should be working fine. Can you try the slandered version?
  • Julien's avatar
    Julien
    What is the "slandered" version ?
  • Julien's avatar
    Julien
    I downloaded and installed the Standard edition of 18.0, retried, and got the same result : segmentation fault upon launching "eclipse-nios2 &" from the nios_command_shell.
    Ahmed_H_Intel1
    I see The Quartus 18 supports Ubuntu 16.04 which means it should work fine.
    Can you attach a screenshot of the error message and the log file of the Quartus?
  • Julien's avatar
    Julien
    This is not a problem with Quartus IDE, but with the NIOS Eclipse IDE to create NIOS BSP.
    Below is a copy/paste of the command I am typing and what I get, there is nothing else happening :
    etabli@bids-etabli:~/intelFPGA/18.0STANDARD/nios2eds$ ./nios2_command_shell.sh
    Altera Nios2 Command Shell [GCC 4]
    Version 18.0, Build 614
    etabli@bids-etabli:~/intelFPGA/18.0STANDARD/nios2eds$ eclipse-nios2
    Segmentation fault
    Ahmed_H_Intel1
    Can I confirm with you the issue?
    I need to escalate this to get confirmed and fixed
    The Quarts version is 18.0 and the NIOS II for Eclipse doesn't start up and doesn't create the BSP..... Correct? Plus you tried the version 17.0 and got no issue, and tried the standard version 18.0 which replicates the issue......correct?
    Can you please send a screen shoot of the error message and the log file?
    Ahmed_H_Intel1
    I confirmed with the engineering team that the Quarts and Qsys support the Ubuntu with no issue. Yes It might be a missing library in Ubuntu 16.04.
