Julien
8 years ago[NIOS2 SBT, Ubuntu 16.04] version 18.0 segmentation Faults at launch, while 17.0 is OK.
Hi, I installed Quartus Lite 18.0 successfully on Ubuntu 16.04, and can use Quartus just fine. But when I try to launch the NIOS2 Eclipse IDE from the "nios2_command_shell", I get a Segmentation Fau...
Ahmed_H_Intel1
8 years agoCan I confirm with you the issue?
I need to escalate this to get confirmed and fixed
The Quarts version is 18.0 and the NIOS II for Eclipse doesn't start up and doesn't create the BSP..... Correct? Plus you tried the version 17.0 and got no issue, and tried the standard version 18.0 which replicates the issue......correct?
Can you please send a screen shoot of the error message and the log file?
