15 years agoNIOS2 Command Shell problem
I am having a number of issues with the Command Shell. It appears the Cygwin installation has not gone to plan. I have the same issue on both an XP and Windows 7 machine. Interestingly i can call make, but most others fail. I really need to use the nios2-c2h-generate-makefile but i always get the following error message (Please note i know its missing the arguments its the same error even with args):
------------------------------------------------ Altera Nios2 Command Shell [GCC 4] Version 10.0, Build 218 ------------------------------------------------ bash-3.1$ nios2-c2h-generate-makefile Can't locate strict.pm in @INC (@INC contains: c:/altera/10.0sp1/quartus/sopc_bu ilder/bin c:/altera/10.0sp1/quartus/sopc_builder/bin/europa /usr/lib/perl5/5.8/c ygwin /usr/lib/perl5/5.8 /usr/lib/perl5/site_perl/5.8/cygwin /usr/lib/perl5/site _perl/5.8 /usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/vendor_perl/5.8/cygwin /us r/lib/perl5/vendor_perl/5.8 /usr/lib/perl5/vendor_perl/5.8 .) at c:/altera/10.0s p1/quartus/sopc_builder/bin/europa/europa_utils.pm line 81. BEGIN failed--compilation aborted at c:/altera/10.0sp1/quartus/sopc_builder/bin/ europa/europa_utils.pm line 81. Compilation failed in require at c:/altera/10.0sp1/quartus/sopc_builder/bin/euro pa/e_object.pm line 52. BEGIN failed--compilation aborted at c:/altera/10.0sp1/quartus/sopc_builder/bin/ europa/e_object.pm line 52. Compilation failed in require at c:/altera/10.0sp1/quartus/sopc_builder/bin/euro pa/e_ptf.pm line 48. BEGIN failed--compilation aborted at c:/altera/10.0sp1/quartus/sopc_builder/bin/ europa/e_ptf.pm line 48. Compilation failed in require at - line 77. BEGIN failed--compilation aborted at - line 77. bash-3.1$ Any ideas on why this is failing on both machines would be greatly appreciated. (I'm using the SBT ans the IDE seems to have issues on Windows 7 and seems to be being replaced by the SBT) Cheerss Drinkyfish
