17 years agoYou should compile only one file for whole system. For exampe, if you've named it my_nios, compile only my_nios.vhd and add +include option with path to quartus dir to vcom command. look at the my_nios file carefully and you can see at the and mini-testbench with DUT instatnce. You can use it as template for you own tb.
