16 years ago
Nios II do not work anymore ...
I made a simple project in Quartus II with a Nios II processor... (with a few I/O)
In the Nios II IDE, I made a simple hello_world_small too...
It was working yesterday (i.e. the I/O worked as I expected with a simple IRQ and the terminal showed me the appropriate message)...
But today, without changing anything, the Nios II processor don't work anymore !
I program the FPGA with the same Quartus II project and I load the same Nios II IDE project !
My IRQ and I/O don't work ! Any message on the console !
Even the reset button has no effect !
Here the only message from the console :
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster ", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Please, can anyone help me ?
    Here is the first console output
    Using cable "USB-Blaster ", device 1, instance 0x00
    Pausing target processor: not responding.
    Resetting and trying again: OK
    Initializing CPU cache (if present)
    OK
    Downloading 00002000 ( 0%)
    Downloaded 3KB in 0.0s
    Verifying 00002000 ( 0%)
    Verified OK
    Leaving target processor paused
    I don't understand why the first pausing target processor is not responding...
    Would it be the problem ?
    your processor is fine i believe. the error message says after resetting processor has become ok.it will respond only when the interrupt comes, are u sure it is coming
    --- Quote Start ---
    --- Quote End ---
    Which interrupt do you mean ?
    Try this (on the console)
    $ cd <your_project_path>/software/<your_nios_project>
    $ nios2-download <executable_elf> -g
    $ nios2-terminal
    greetings
