17 years agoBy asynchronous RAM, do you mean you present put a read address out, it gets data from the RAM asynchronously, and then you clock the data into the FPGA, all within 10ns? Most RAMs have a sizable access time and this just isn't possible. (You might also mean that the RAM doesn't have a clock, but are doing everything over multiple stages.)
You don't need to know the source register to make an assignment. For something quick, just do a set_max_delay -to [get_ports addressname*]. (I'm guessing you're using TAN, but would strongly suggest switching to TimeQuest when you can.) In TAN, just put a Tco assignment on the pins in the Assignment Editor. In both cases, you don't need to know the source register's name. Recompile so the fitter now tries to meet your tight requirement. In TAN, go to the Tco panel, find the worst Tco for that bus, and right-click List Paths. It will show the path in detail below, where you can break out all the components(clock delay, data delay, etc.) The main thing you are looking for are: 1) Did it use an I/O register 2) Is the output delay chain as fast as possible(only some architectures have an output delay chain, and it is almost always bypasses unless you have min Tco requirement, so this isn't that big of a deal). You can also find out about both of these in the Fitter Report -> Resource Utilization. There will be an Output Pins section that has a column saying if the output registers is used, and there will be a Delay Chains Report here also that tells what the delay chains are set to(0 is the fastest). Just another way to skin the cat. If you're using the I/O register and have no delay chain, then from a fitter perspective there's nothing else you can do. You can increase the Current Strength on the I/O, and in SIII you can increase the edge rate. Note that this is not the correct way to do timing analysis, i.e. you're making up a number for your Tco and trying to get it as tight as possible. The correct way, for example, would be to calculate it off the system requirements. For example, if you have a 10ns turnaround time, and the RAM access time was 5ns and the board traces were 500ps total, then you would be using 5.5ns of that period outside the device. That would mean your Tco and Tsu requirements would have to be 4.5ns total(you'd have to split between the two requirements, which would be some trial and error), but as I said, you probably won't make timing, if that's what you're trying to do. Note that timing models will be slower than what you're seeing on the board. Static Timing Analysis slow models use worst case conditions, which is what you want to reliably ship a product, but most board tests are not under worst case Process, Voltage and Temperature(PVT).
