NIOS 2 First steps
What is done for now:
I installed Quartus Prime Lite 20.1.1 and do a sample procect, 'Blinky'. I get also the simulation running and all looks fine.
I started a project for my own, using ATLPLL and some counters, ffs and somthing like this. Works out.
I search a lot to find a way to get the NIOS 2 tool chain (Eclipse) running. OK, starts, no idea if it works.
I try to find a tutorial and end up at AN-717. Great stuff, but I should add a NIOS II core from my IP catalog, but there is no !!!!
Whats wrong now?
I have another machine I installed Quartus some days ago, here without the NIOS 2 tool chain and no eclipse and same problem.
==> the installation of the NIOS 2 tool chain isn't the problem.
So whar can I do now?
Se my IP catalog here:
With best regards
Gerhard
- BoonBengT_Altera5 years ago
Moderator
Hi @Gerhard56,
Thank you for posting in Intel community forum and hope this message find you well, apologies for the delayed in response.
Apologies for the inconvenient face,on the up catalog shows it that in the quartus tool?
And for the user guide AN717, you are referring to steps 1.5.5.3?For that steps you will be able to find the NIOS II core in the Platform designer ip catalog.
Please do let me know if I misunderstand the your situation.
Warm regards.
BB- BoonBengT_Altera5 years ago
Moderator
Hi @Gerhard56,
Hope this message find you well, by any chances did you managed to look into the clarification above?
Warm regards
BB
- Gerhard565 years ago
Hi BB,
yes I am well. Get my vaxins first round, hope I win.
I get the problems solved, I have now a running logic on my FPGA and currently try to control it with the help of an NIOS 2. The NIOS 2 hardware part is done, I had recently troubles to get it running, but this was my mistake.
Now I try to get FreeRTOS running on the soft core, and this isn't that easy. The Eclipse tool and the other tools involved are totally new for me (normally using Visual Studio or Atmel Studio) and than the WSL (Windows subsystem for Linux) ...
It is no fun.
With best regards
Gerhard
