11 years agonewbie in vhdl
good afternoon people. I'm a newbie in vhdl and i have problems about test bench. My area director has left me some problems. If anyone could help me with logs and the last two problems. the li...
11 years agoone of my problems about test bench is the next: Design and Simulate a 12-Bit Magnitude Comparator using a cascade of three 74F85
4-Bit Magnitude ComparatorsVHDL CODE (COMPILE GOOD)
library ieee;
use ieee.std_logic_1164.all;
entity comparador_12 is
port( num1 : in std_logic_vector(3 downto 0);
num2 : in std_logic_vector(3 downto 0);
menor : out std_logic;
igual : out std_logic;
mayor : out std_logic
end comparador_12;
architecture behavioral of comparador_12 is
begin
process(num1,num2)
begin
if (num1&num1&num1 > num2&num2&num2 ) then
menor <= '0';
igual <= '0';
mayor <= '1';
elsif (num1&num1&num1 < num2&num2&num2) then
menor <= '1';
igual <= '0';
mayor <= '0';
else
menor <= '0';
igual <= '1';
mayor <= '0';
end if;
end process;
end behavioral;
TEST BENCH
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity comparador_12_tb is
end comparador_12_tb;
architecture behavior of comparador_12_tb is
--declaro mis señales de entrada
signal num1,num2 : std_logic_vector(3 downto 0) :=(others => '0');
signal menor,igual,mayor : std_logic:='0';
begin
--instancia de entidad
UUT : work.comparador_12 port map(num1,num2,menor,igual,mayor);
--definicion del estimulo de proceso
tb : process
begin
num1&num1&num1<="100111000100"; --num1 = 2500
num2&num2&num2<="111011011000"; --num2 = 3800
wait for 10 ns;
num1&num1&num1<="100110011001"; --num1 = 2457
num2&num2&num2<="010111100011"; --num2 = 1507
wait for 10 ns;
num1&num1&num1<="111111111111"; --num1 = 4095
num2&num2&num2<="111111111111"; --num2 = 4095
wait for 10 ns;
num1&num1&num1<="100010001000"; --num1 = 2184
num2&num2&num2<="001101110111"; --num2 = 887
wait;
end process tb;
end; when compile with tb i have 10 errores. The next is Error (10500): VHDL syntax error at comparador_12_tb.vhd(19) near text "&"; expecting "(", or "'", or "."
