16 years ago
New to VHDL. Help with errors
Can you tell me why im getting these errors for this code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY DAC2 IS
PORT( hardwarecontrol: IN STD_LOGIC; -- Control Hardware Shut Down
input: IN STD_LOGIC_VECTOR (11 DOWNTO 0); -- Input Value for sine wave
clock: IN STD_LOGIC; -- Clock Input from Altera Board
cs: OUT STD_LOGIC; -- Chip Select
sck: OUT STD_LOGIC; -- Serial Clock Input
sdi: OUT STD_LOGIC; -- Serial Data Input
ldac: OUT STD_LOGIC; -- Latch DAC Input
shdn: OUT STD_LOGIC -- Hardware Shutdown Input
END DAC2;
ARCHITECTURE behaviour OF DAC2 IS
SIGNAL count: STD_LOGIC_VECTOR (3 DOWNTO 0);
BEGIN
sck <= clock;
IF RISING_EDGE(clock) THEN
IF (hardwarecontrol = '1') THEN
cs <= '0';
ldac <= '1';
PROCESS(clock,input)
BEGIN
IF (count = "0000") THEN
sdi <= '0';
ELSIF (count = "0001") THEN
sdi <= '1';
ELSIF (count = "0010") THEN
sdi <= '0';
ELSIF (count = "0011") THEN
sdi <= '1';
ELSIF (count = "0100") THEN
sdi <= input(11);
ELSIF (count = "0101") THEN
sdi <= input(10);
ELSIF (count = "0110") THEN
sdi <= input(9);
ELSIF (count = "0111") THEN
sdi <= input(8);
ELSIF (count = "1000") THEN
sdi <= input(7);
ELSIF (count = "1001") THEN
sdi <= input(6);
ELSIF (count = "1010") THEN
sdi <= input(5);
ELSIF (count = "1011") THEN
sdi <= input(4);
ELSIF (count = "1100") THEN
sdi <= input(3);
ELSIF (count = "1101") THEN
sdi <= input(2);
ELSIF (count = "1110") THEN
sdi <= input(1);
ELSIF (count = "1111") THEN
sdi <= input(0);
cs <= '1';
ldac <= '0';
shdn <= '1';
END IF;
count <= count +1;
END PROCESS;
ELSIF (hardwarecontrol = '0') THEN
count <= "0000";
END IF;
END IF;
END behaviour;
Error (10500): VHDL syntax error at DAC2.vhd(26) near text "IF"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at DAC2.vhd(26) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at DAC2.vhd(27) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at DAC2.vhd(85) near text "ELSIF"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at DAC2.vhd(85) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at DAC2.vhd(87) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture
    hello everyone...
    can anyone tell me whats wrong wif diz code?
    component RAM is
    generic (K, W: integer); -- number of address and data bits
    port (WR: in std_logic); -- active high write enable
    ADDR : in std_logic_vector (W-1 downto 0); -- RAM address
    DIN: in std_logic_vector (K-1 downto 0); -- write data
    DOUT: out std_logic_vector (K-1 downto 0); -- read data
    end component RAM;
    i new with vhdl, i now working my final year project using vhld, so i in learning process.
    this code give me error 10500
    "Error (10500): VHDL syntax error at fifo.vhd(25) near text "ADDR"; expecting "end""
    TQVM in advance...
