13 years agoHi, In your Clock_Gen_100Hz process you have used KEY(0) as asyn reset.Instead of that give high priority to reset and within clcok give priority to key(0).I have modified as
IF(reset='1') THEN --KEY0 is the asynchronous reset button clock_1k <= '0'; loopcount := 0; ELSIF(clock_50'event AND clock_50 = '1') THEN IF(KEY(0) = '0') THEN clock_1k <= '0'; loopcount := 0; elsif(loopcount = 2499999) then loopcount := 0; clock_1k <= not clock_1k; --flip clock_10K else loopcount := loopcount + 1; end if; END IF; And Dont forget remove assignment of clock_1k <= '0'; from FSM process.
