EHait
3 years agoNew Project based on the old one
Hi. I made a completely new design, using the same MAX10 FPGA so in order to save some work i just copied the old Quartus project (LB_COMM_TESTER.qpf) to another folder, renamed it to th new project...
roeekalinsky
Contributor
3 years agoHi Eli,
In the Quartus project flow, the .qpf file is not the only file that contains project information. Did you update the .qsf file as well?
And if I may offer a more general observation: Seems to me that if the only commonality between your new design and the old one is the FPGA part number, then your approach of modifying the old project instead of just creating a new clean-sheet project is probably a false economy. It's actually more work and more error-prone.
-Roee
