17 years ago --- Quote Start --- Hi Alessio, which timing analyzer did you use ? Classic Timing Analyzer ? I assume you have specified at least your required clock speed and the report shows you that your design is too slow ??? Kind regards GPK --- Quote End --- Hi pletz, thank you for the answer. I specified "default required fmax" to 96 MHz (the frequency I need) and nothing more. A colleague suggest me to ignore these messages, at the moment, because it may be I don't specify all the requirements that Quartus needs. I think it is possible so...I'll try to set all the parameters I can. Thank you again. Regards, Alessio.
