17 years ago --- Quote Start --- Hello, everybody. I've a small problem with Quartus II message report. First of all, when I compile my project, time requirements are not met. I read the report and I found a lot of errors related to "Setup Time". I think there's a problem with required longest p2p time, because it has a negative value. Obviously, "actual longest p2p time" can't be a negative number and so all goes wrong. Could someone help me about this? If you need more information, please ask and i'll give you. At the moment I don't know what is useful or not.:p Thanks in advance, Alessio. --- Quote End --- Hi Alessio, which timing analyzer did you use ? Classic Timing Analyzer ? I assume you have specified at least your required clock speed and the report shows you that your design is too slow ??? Kind regards GPK
