11 years agoNeed Up To Date Tutorial on Pin Assignments with Schematic Entry
I'm new to Altera Schematic entry tools for their FPGA's. I used Xilinx tools several years ago, but decided to give Altera a try. Anyhow, I downloaded the tutorial "tut_quartus_intro_schem.pdf" wh...
11 years ago --- Quote Start --- More easily, create your schematic entry, just run analisys and synthesis and then use the pin planner tool inside QII to give I/O assignment. --- Quote End --- Thanks. Here is what I did. I clicked PROCESSING-> START-> START ANALYSIS AND SYNTHESIS Then let it compile for a bit. When done, I clicked ASSIGNMENTS-> PIN PLANNER My nodes were listed at the bottom of the screen so I just picked the pins I wanted from that. I could also pick the pin I wanted directly and change it to the node. When that was done, I clicked PROCESSING-> START I/O ASSIGNMENT ANALYSIS It compiled again, but wasn't happy with my pin selections. I reassigned them, not sure if I did it right, but after a few iterations, the compiler reports 0 errors, 3 warnings. 1. Parallel compilation needs a license. 2. Logiclock needs a license. 3. Pins must meet Altera requirements for 3.3V interfaces and specifically names my two inputs. I think I can probably ignore warning# 1. Not sure about# 2 because I don't know what logiclock is. Is# 3 just Altera's way of saying the pin is not 5V tolerant? Anyhow, hopefully this will get me to the next step of the tutorial.
