Hello Jigalong; I have modified your code below to be a bit cleaner and address the issue that mazel mentioned above, as well as remove the "null" statements which are not valid & change to VHDL 2008. This is a good illustration of some of the basic constructs that make 2008 a bit cleaner. -James
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity MetroLRT is
port(
clk: in bit;
rst: in bit;
task: in bit_vector(1 downto 0);
stationed: in bit_vector(3 downto 0);
timeSTP: in bit;
serial_in_port: buffer std_logic;
serial_out_port: out bit;
gate_open_out: out bit
end MetroLRT;
architecture rtl of MetroLRT is
--signal
signal header1: std_logic_vector(3 downto 0);
signal balance1: std_logic_vector(6 downto 0);
signal t_stamp1: std_logic;
signal card_in1: std_logic_vector(15 downto 0);
signal station1: std_logic_vector(3 downto 0);
signal serial_count: bit;
signal buf: std_logic;
begin
process(all)
--variable
begin
if not(rst) then
serial_in_port <= '0';
elsif rising_edge(clk) then
if serial_in_port then
buf <= serial_in_port;
--store card info to all temporary variables
card_in1 <= X"0000" ;
header1 <= X"A";
t_stamp1 <= '1';
station1 <= X"0";
end if;
end if;
end process;
enter_station: process(all)
begin
if task = "00" then
if header1 = "1010" then
if balance1 >= "0001000" then
if t_stamp1 = '1' then
card_in1 <= X"0000";
station1 <= "0000";
gate_open_out <= '1';
else
gate_open_out <= '0';
end if;
end if;
end if;
end if;
end process;
end rtl;
