10 years agoNeed help with testbench driving serial data out @ different clock rates, Please :)
TestBench fills an 8 bit by 16 registers array with random numbers then serially shifts it to the TDM serial input. The TDM will be coming from a Sharc DSP @ 8bit x 16 slots and continuous frames and...
10 years agoYou can run the simulation for as long as you want typing:
run X ns/us/ms/s or even run -all (runs until all transactions are complete or simulation is forced to stop) Into the console.eg: run 100 us runs for 100 micro seconds. as for an example - how about this?:
data_48khz_proc : process
variable seed1, seed2 : positive;
variable rand : real;
alias internal_48khz : std_logic is <<signal tdm_uut.some_ent1.some_ent2.clk_192khz : std_logic >>;
variable rnd_val : std_logic_vector(7 downto 0);
begin
for bitcnt in 0 to 7 begin
if bitcnt = 0 then
uniform(seed1, seed2, rand); -- generate random number
rand_num <= integer(rand*range_of_rand); -- rescale to 0.250, convert integer part
rnd_val <= std_logic_vector(to_unsigned(rand_num, max_bits+1));
end if;
input <= rnd_val(bit_cnt);
wait until rising_edge(internal_48khz);
end loop;
end process;
