16 years ago
need help with nodes connection in block diagram
http://img338.imageshack.us/img338/9634/123mas.jpg
i need to connect data_out[7..0] to the second block to M[1..0],
but i need that only bits, data_out(0) and data_out(1) will be connect to this vector M. and for example data_out(3) to the FIN_RE node and data_out(4) to FIN_UN...
how can i do this???? thank you Alex.
    1. Delete wire.
    2. Extend a short wire from Data_out[7..0] and type do[7..0] or any name you want.
    3. Extend a short wire from M[1..0] and type do0,do1
    4. Extend a short wire from FIN_RE and write do3
    5. Extend a short wire from FIN_UN and write do4
    do[7..0] is same to do7,do6,do5,...,do0
    --- Quote Start ---
    --- Quote End ---
    Please check the attachment, you can see the 4 bits of AccDelay[3..0] are assigned to a[1],a[3],a[5],a[7] respectly!
