10 years agoNeed help with my final project design (Ethernet Transmitter)
Hi all, My goal is to build Ethernet Transmitter based pipeline. I already built few things and I have few questions: 1. I want to take my input (ethernet 2 / 802.3 frames) from a TEX...
10 years ago --- Quote Start --- There is no quick guide. And knowing software languages will be of little help to you. You cannot just send an entire ethernet frame/clock with some random flip flops around. I highly suggest you find a textbook about digital logic, and then when you understand that - find a VHDL tutorial. This is NOTHING like writing software. --- Quote End --- Hi Tricky, I know digital logic and I already designed circuits in the past. I don't understand why I can't send entire ethernet frame per clock? Let me try to explain myself better: I am planning to use/write: 1. load input to 3 FIFO stacks (maybe create a quick GUI with MATLAB for this). 2. Add VLAN and priority if needed (802.1 model). 3. create CRC model 4. Assembly the ethernet frame model. 5. Transmite model. Yes, I still don't know how to start, and that's why I want to understand my limits and possibilities with the FPGA. why can I pass 4 bits in one clock and why I can't pass 1500 bytes in one clock? - I don't want to do anything with these 1500 Bytes besides assembly them together at the end. (isn't it depended on the size of the register?) also, I don't understand how can I design a control unit? Thanks Tricky!
