13 years ago
NEED HELP! Verilog Digital Alarm Clock implementation on Altera DE2 Board
Hello Guys, I have been trying to implement a digital alarm clock using verilog, which can be turned off using a motion sensor and sends the sound output to a buzzer(its all implemented on the Altera DE2 board). I was able to make the clock work, and then I made the alarm part and it doesnt trigger the alarm. i assigned the alarm to an LED so if it gets triggered it should light up But for some reason my code broke. id appreciate some helpmodule inputmux(alarm_key_out, alarm_sw_out, clock_key_out, clock_sw_out, select, key_in, sw_in);
//Used to direct the control input to the alarm/clock
output reg alarm_key_out, alarm_sw_out, clock_key_out, clock_sw_out;
input select, key_in, sw_in;
always@(select)
case (select)
0: begin
clock_key_out = key_in;
clock_sw_out = sw_in;
end
1: begin
alarm_key_out = key_in;
alarm_sw_out = sw_in;
end
endcase
endmodule
module outputmux(hours_out, minutes_out, select, alarm_min_in, alarm_hours_in, clock_min_in, clock_hours_in);
parameter n = 8;
output reg [n-1 : 0] hours_out, minutes_out;
input [n-1: 0] alarm_min_in, alarm_hours_in, clock_min_in, clock_hours_in;
input select;
always @(select)
case (select)
0: begin
hours_out = clock_hours_in;
minutes_out = clock_min_in;
end
1: begin
hours_out = alarm_hours_in;
minutes_out = alarm_min_in;
end
endcase
endmodule
//Right now our counter only counts to 30 (or 12). If we change it to 60 then 1 minute == 2 minutes in real time.
//Check if the hour rolls over from at 30, I suspect that the clock hits 30, then has to hit 30 again. In which case it's a BCD error.
//Note: a roll over will *not* occur if the clock is in manual mode.
module nBitCounter(count, reset_sig, CLK, manCLK, toggle);
parameter n = 8; // output size defualt 8 bit, must be able to store bitwise k value
parameter k = 30; // ceiling
output reg [n-1:0] count;
output reg reset_sig; //Meant for a high output when count resets
input CLK, manCLK, toggle;
wire clockline;
assign clockline = toggle ? manCLK : CLK;
// Increment count on clock + also has seed value
always @(posedge clockline) //or posedge seed <- this breaks things
begin
if (count == k-1) begin
count = 0;
reset_sig = ~reset_sig;
end
else begin
count = count + 1;
end
end
endmodule
module demuxer(a, s_in, x, y);
input a;
input s_in;
output reg x, y;
always @(a, s_in)
begin
case(s_in)
1: x = a;
0: y = a;
default: x = a;
endcase
end
endmodule
module sevenSegmentDisplay(ssOut, nIn);
output reg [0:6] ssOut;
input [3:0] nIn;
always @(nIn)
case (nIn)
4'b0000: ssOut = 7'b0000001;
4'b0001: ssOut = 7'b1001111;
4'b0010: ssOut = 7'b0010010;
4'b0011: ssOut = 7'b0000110;
4'b0100: ssOut = 7'b1001100;
4'b0101: ssOut = 7'b0100100;
4'b0110: ssOut = 7'b0100000;
4'b0111: ssOut = 7'b0001111;
4'b1000: ssOut = 7'b0000000;
4'b1001: ssOut = 7'b0001100;
endcase
endmodule
module binary_to_BCD(A,ONES,TENS,HUNDREDS);
input [7:0] A;
output [3:0] ONES, TENS;
output [1:0] HUNDREDS;
wire [3:0] c1,c2,c3,c4,c5,c6,c7;
wire [3:0] d1,d2,d3,d4,d5,d6,d7;
assign d1 = {1'b0,A[7:5]};
assign d2 = {c1[2:0],A[4]};
assign d3 = {c2[2:0],A[3]};
assign d4 = {c3[2:0],A[2]};
assign d5 = {c4[2:0],A[1]};
assign d6 = {1'b0,c1[3],c2[3],c3[3]};
assign d7 = {c6[2:0],c4[3]};
add3 m1(d1,c1);
add3 m2(d2,c2);
add3 m3(d3,c3);
add3 m4(d4,c4);
add3 m5(d5,c5);
add3 m6(d6,c6);
add3 m7(d7,c7);
assign ONES = {c5[2:0],A[0]};
assign TENS = {c7[2:0],c5[3]};
assign HUNDREDS = {c6[3],c7[3]};
endmodule
module add3(in,out);
input [3:0] in;
output [3:0] out;
reg [3:0] out;
always @ (in)
case (in)
4'b0000: out <= 4'b0000;
4'b0001: out <= 4'b0001;
4'b0010: out <= 4'b0010;
4'b0011: out <= 4'b0011;
4'b0100: out <= 4'b0100;
4'b0101: out <= 4'b1000;
4'b0110: out <= 4'b1001;
4'b0111: out <= 4'b1010;
4'b1000: out <= 4'b1011;
4'b1001: out <= 4'b1100;
default: out <= 4'b0000;
endcase
endmodule
module alarmstatecontroller(buzzerout, alarmtoggle, alarmstop, alarmstart, clk);
// This is the FSM. The buzzerout (currently represented by LEDG) does not actually
// turn off. It may have to do with the switch in which case we can remove it. I don't think
// namespace is an issue but look into it. It might be worth while to assign LEDs to the states to see if
// they actually change.
output reg buzzerout;
input alarmtoggle, alarmstop, alarmstart, clk;
wire trigger, dead;
assign trigger = alarmtoggle ? alarmstart : dead;
parameter n = 3;
parameter IDLE = 3'b001, RING = 3'b010;
reg [n - 1:0] STATE;
always @(trigger or alarmstop)
begin
case(STATE)
IDLE:
begin
buzzerout = 'b0;
if (trigger)
STATE = RING;
end
RING:
begin
if (alarmstop)
STATE = IDLE;
else begin
buzzerout = 1'b1;
end
end
default: STATE = IDLE;
endcase
end
endmodule
module alarmregister(alarmtrigger, clockhour, clockminute, alarmhour, alarmminute);
output reg alarmtrigger;
input [7:0]clockhour, clockminute, alarmminute, alarmhour;
always @(clockminute, clockhour, alarmminute, alarmhour)
begin
if (clockminute == alarmminute && clockhour == alarmhour) begin
alarmtrigger = 1'b1;
end else begin
alarmtrigger = 'b0;
end
end
endmodule
module clock(HEX3, HEX2, HEX1, HEX0, LEDR, LEDG, SW, KEY, CLOCK_50);
output [0:6]HEX3, HEX2, HEX1, HEX0;
output [1:0]LEDR, LEDG;
input [3:0] SW, KEY;
input CLOCK_50;
supply0 groundline;
wire mainclock, minuteclock, hourclock, inputtoclocksetsw, inputtoclocksetkey, clocksetminute, clocksethour;
wire alarmsetminute, alarmsethour, inputtoalarmsetkey, inputtoalarmsetsw, alarmtofsm;
wire [3:0] bcdminutesones, bcdminutestens, bcdhoursones,bcdhourstens;
wire [7:0]displayminutes, displayhours, clockminutesoutput, clockhoursoutput, alarmminutesout, alarmhoursout;
//Controls whats displayed on the HEX displays
inputmux ChangeInputController(inputtoalarmsetkey, inputtoalarmsetsw, inputtoclocksetkey, inputtoclocksetsw, SW[2], ~KEY[0], SW[0]);
outputmux ChangeOutputController(displayhours, displayminutes, SW[2], alarmminutesout, alarmhoursout, clockminutesoutput, clockhoursoutput);
demuxer ClockDeMux(inputtoclocksetkey, inputtoclocksetsw, clocksetminute, clocksethour);
demuxer AlarmDeMux(inputtoalarmsetkey, inputtoalarmsetsw, alarmsetminute, alarmsethour);
//Display Control
binary_to_BCD Minutes(displayminutes,bcdminutesones,bcdminuteste ns,HUNDREDS);
binary_to_BCD Hours(displayhours,bcdhoursones,bcdhourstens,HUNDR EDS);
sevenSegmentDisplay HexDisplayMinutesZero(HEX0, bcdminutesones);
sevenSegmentDisplay HexDisplayMinutesOne(HEX1, bcdminutestens);
sevenSegmentDisplay HexDisplayHoursZero(HEX2, bcdhoursones);
sevenSegmentDisplay HexDisplayHoursOne(HEX3, bcdhourstens);
//Create seconds tick
nBitCounter ClockDelay(count, mainclock, CLOCK_50, seed, toggle);
defparam ClockDelay.n = 25;
defparam ClockDelay.k = 25000000;
assign LEDR[0] = mainclock;
//Count Seconds
nBitCounter SecondsTick(count, minuteclock, mainclock, seed, SW[1]);
//Count Minutes
nBitCounter MinutesTick(clockminutesoutput, hourclock, minuteclock, clocksetminute, SW[1]);
//Count Hours
nBitCounter HoursTick(clockhoursoutput, reset_sig, hourclock, clocksethour, SW[1]);
defparam HoursTick.k = 12;
//Alarm Minutes
nBitCounter AlarmMinuteCounter(alarmminutesout, reset_sig, CLK, alarmsetminute, SW[1]);
//Alarm Hours
nBitCounter AlarmHourCounter(alarmhoursout, reset_sig, CLK, alarmsethour, SW[1]);
defparam AlarmHourCounter.k = 12;
//Alarm Triggering
alarmregister AlarmRegisterComp(alarmtofsm, clockhoursoutput, clockminutesoutput, alarmhoursout, alarmminutesout);
assign LEDR[1] = alarmtofsm;
//When the FSM is enabled the LED (means alarm is triggered) does not light up.
//alarmstatecontroller AlarmSoundControl(LEDG[0], SW[3], ~KEY[2], alarmtrigger, mainclock);
endmodule
