12 years agoHi anakha,
I am adding a IR Module that i have found in the net to the existing updowncount module. I have test my existing module and is working well. This is how my existing module work. At irst=0 (which is key0 on the DE2 board) otvalue is set to 127. At iup=0 (which is key1 on the DE2 board) otvalue will start to count up At idown=0 (which is key2 on the DE2 board) otvalue will start to count down. Now i want to add an IR module so i can control it via the remote control as well as the key on the de2 board. This is the IR demo module i found online which i have test it and it work too. Below is the code : module IR_RECEIVE( iCLK, //clk 50MHz iRST_n, //reset iIRDA, //IR code input oDATA_READY, //data ready oDATA //decode data output ); //======================================================= // PARAMETER declarations //======================================================= parameter IDLE = 2'b00; //always high voltage level parameter GUIDANCE = 2'b01; //9ms low voltage and 4.5 ms high voltage parameter DATAREAD = 2'b10; //0.6ms low voltage start and with 0.52ms high voltage is 0,with 1.66ms high voltage is 1, 32bit in sum. parameter IDLE_HIGH_DUR = 262143; // data_count 262143*0.02us = 5.24ms, threshold for DATAREAD-----> IDLE parameter GUIDE_LOW_DUR = 230000; // idle_count 230000*0.02us = 4.60ms, threshold for IDLE--------->GUIDANCE parameter GUIDE_HIGH_DUR = 210000; // state_count 210000*0.02us = 4.20ms, 4.5-4.2 = 0.3ms < BIT_AVAILABLE_DUR = 0.4ms,threshold for GUIDANCE------->DATAREAD parameter DATA_HIGH_DUR = 41500; // data_count 41500 *0.02us = 0.83ms, sample time from the posedge of iIRDA parameter BIT_AVAILABLE_DUR = 20000; // data_count 20000 *0.02us = 0.4ms, the sample bit pointer,can inhibit the interference from iIRDA signal //======================================================= // PORT declarations //======================================================= input iCLK; //input clk,50MHz input iRST_n; //rst input iIRDA; //Irda RX output decoded data output oDATA_READY; //data ready output [31:0] oDATA; //output data,32bit //======================================================= // Signal Declarations //======================================================= reg [31:0] oDATA; //data output reg reg [17:0] idle_count; //idle_count counter works under data_read state reg idle_count_flag; //idle_count conter flag //wire idle_count_max; reg [17:0] state_count; //state_count counter works under guide state reg state_count_flag; //state_count conter flag reg [17:0] data_count; //data_count counter works under data_read state reg data_count_flag; //data_count conter flag reg [5:0] bitcount; //sample bit pointer reg [1:0] state; //state reg reg [31:0] data; //data reg reg [31:0] data_buf; //data buf reg data_ready; //data ready flag //======================================================= // Structural coding //======================================================= assign oDATA_READY = data_ready; //idle counter works on iclk under IDLE state only always @(posedge iCLK or negedge iRST_n) if (!iRST_n) idle_count <= 0; else if (idle_count_flag) //the counter works when the flag is 1 idle_count <= idle_count + 1'b1; else idle_count <= 0; //the counter resets when the flag is 0 //idle counter switch when iIRDA is low under IDLE state always @(posedge iCLK or negedge iRST_n) if (!iRST_n) idle_count_flag <= 1'b0; else if ((state == IDLE) && !iIRDA) idle_count_flag <= 1'b1; else idle_count_flag <= 1'b0; //state counter works on iclk under GUIDE state only always @(posedge iCLK or negedge iRST_n) if (!iRST_n) state_count <= 0; else if (state_count_flag) //the counter works when the flag is 1 state_count <= state_count + 1'b1; else state_count <= 0; //the counter resets when the flag is 0 //state counter switch when iIRDA is high under GUIDE state always @(posedge iCLK or negedge iRST_n) if (!iRST_n) state_count_flag <= 1'b0; else if ((state == GUIDANCE) && iIRDA) state_count_flag <= 1'b1; else state_count_flag <= 1'b0; //data read decode counter based on iCLK always @(posedge iCLK or negedge iRST_n) if (!iRST_n) data_count <= 1'b0; else if(data_count_flag) //the counter works when the flag is 1 data_count <= data_count + 1'b1; else data_count <= 1'b0; //the counter resets when the flag is 0 //data counter switch always @(posedge iCLK or negedge iRST_n) if (!iRST_n) data_count_flag <= 0; else if ((state == DATAREAD) && iIRDA) data_count_flag <= 1'b1; else data_count_flag <= 1'b0; //data reg pointer counter always @(posedge iCLK or negedge iRST_n) if (!iRST_n) bitcount <= 6'b0; else if (state == DATAREAD) begin if (data_count == 20000) bitcount <= bitcount + 1'b1; //add 1 when iIRDA posedge end else bitcount <= 6'b0; //state change between IDLE,GUIDE,DATA_READ according to irda edge or counter always @(posedge iCLK or negedge iRST_n) if (!iRST_n) state <= IDLE; else case (state) IDLE : if (idle_count > GUIDE_LOW_DUR) // state chang from IDLE to Guidance when detect the negedge and the low voltage last for > 4.6ms state <= GUIDANCE; GUIDANCE : if (state_count > GUIDE_HIGH_DUR)//state change from GUIDANCE to DATAREAD when detect the posedge and the high voltage last for > 4.2ms state <= DATAREAD; DATAREAD : if ((data_count >= IDLE_HIGH_DUR) || (bitcount >= 33)) state <= IDLE; default : state <= IDLE; //default endcase //data decode base on the value of data_count always @(posedge iCLK or negedge iRST_n) if (!iRST_n) data <= 0; else if (state == DATAREAD) begin if (data_count >= DATA_HIGH_DUR) //2^15 = 32767*0.02us = 0.64us data[bitcount-1'b1] <= 1'b1; //>0.52ms sample the bit 1 end else data <= 0; //set the data_ready flag always @(posedge iCLK or negedge iRST_n) if (!iRST_n) data_ready <= 1'b0; else if (bitcount == 32) begin if (data[31:24] == ~data[23:16]) begin data_buf <= data; //fetch the value to the databuf from the data reg data_ready <= 1'b1; //set the data ready flag end else data_ready <= 1'b0 ; //data error end else data_ready <= 1'b0 ; //read data always @(posedge iCLK or negedge iRST_n) if (!iRST_n) oDATA <= 32'b0000; else if (data_ready) oDATA <= data_buf; //output endmodule So now i am having problem to modify my updowncount module. I tried to write the code in several ways but is still fail. kindly advice me =D
