13 years ago --- Quote Start --- attached you can find the zip-file (included: tcl-file). --- Quote End --- There is no Tcl simulation file in there that you wrote. Only you know what component should be simulated, so you should really write one yourself. Here's what I did. 1) Unzipped the zip file, into eg., c:/temp/klause, which created c:/temp/klause/D8PSK 2) Started Modelsim-ASE and changed directory to c:/temp/klause and typed vlib work to create a work folder. Typing 'vmap work' shows that the work folder maps to the default location ./work. If you don't see that, type 'vmap work ./work' 3) Compile the source vcom D8PSK/nco.vho vcom D8PSK/MY_TESTBENCH/tb_D8PSK.vhd this fails, since your testbench is trying to simulate your project top-level entity, whereas you want to simulate the nco, so I edited the file and changed the code to 'dut : entity work.nco', and then it compiled fine. 4) Simulate vsim -novopt tb_D8PSK add wave * run 10 us It worked fine. What didn't work for you? Cheers, Dave
