ugro
2 years agoNativeLink RTL-Simulation fails after Fitter-Run if project includes two variations of GPIO Lite IP
Hi, RTL-Simulation with Questa Intel Starter FPGA Edition using Nativelink fails under following conditions: there are two variations of the GPIO Lite Intel FPGA IP core included; any task other ...
RichardT_altera
2 years agoIt might be a potential bug and I will confirm this with the engineering.
1) Run Analysis & Synthesis ->RTL simulation Passed.
2) Run Analysis & Synthesis, Then Run Fitter -> RTL simulation Error.
3) Run Fitter directly -> RTL simulation Passed.
Case (3) is particularly interesting as it works after fitter stage. I recommend avoiding situation (2) as a workaround.
FYI, in cases where this error arises in Quartus Standard, we can only provide a workaround unless there's no available solution.
Richard Tan
