16 years ago --- Quote Start --- I don't know about Synplify Pro, but I had similar problems with NativeLink and ModelSim. IMHO, NativeLink is broken in many ways. My solution was to use the ".SV" extension in the filename. Files with the SV extension are automatically assumed to be SystemVerilog by ModelSim. May be this would work with Synplify Pro as well. pletz: According to him, NativeLink is overriding the Synplify Pro configuration by overwriting the Synplify Pro configuration file. That was exactly the same issue I had with ModelSim. --- Quote End --- Hi, I played a little bit with the "native-if" of SynplifyPro and Quartus. Both IF do not pass all constraints to the other tool. In my point of view they are not useable. Kind regards GPK
