16 years ago --- Quote Start --- I can run with no errors if I run Synplify Pro independantly, there is no problem here. The functionality I'm trying to get is to have Synplify Pro launched from Quartus using NativeLink. When I attempt this, Quartus doesn't set the appropriate settings to allow SV extensions and syntax. It also seems to ignore settings set in the prj file when I manually edit in what I want, and overwrites the prj file with it's incorrect settings. Thanks -mark --- Quote End --- Hi, I tried it the other way round. Quartus also ignores the SV setting in SynplifyPro. But why will set in Quartus the option to SV ? In my point of view it should be done in SynplfyPro, because it is used as synthesis tool. If it is set in SynplifyPro it should stay in the project file. Kind regards GPK
