16 years agoI can run with no errors if I run Synplify Pro independantly, there is no problem here. The functionality I'm trying to get is to have Synplify Pro launched from Quartus using NativeLink. When I attempt this, Quartus doesn't set the appropriate settings to allow SV extensions and syntax. It also seems to ignore settings set in the prj file when I manually edit in what I want, and overwrites the prj file with it's incorrect settings.
Thanks -mark
