13 years ago
NativeLink error in Quartus II 13.1 for Modelsim
Hello people,
I am having a completely ununderstandable error. After I compile my code in Quartus II 13.1 and try to run Modelsim through Quartus (Nativelink) I get a strange error:
NONE.
Check the Nativelink log file C:................................ for detailed error messages.
The Modelsim Altera path is set correctly and sometimes it runs, sometimes it doesn't. Now it cannot run.
What is wrong??
Thank you
    Did you open the report file?
    If you are using the Quartus Web Edition ( free ) you have to use Model-Sim Altera Starter. This appears as "ModelSim-Altera" when you set your simulation tool. Did you choose "ModelSim" instead?
    Anyway, post the contents of nativelink report.
    Hi!
    I am using Quartus II 64-bit version 13.1.0 Build 162 10/23/2013 SJ Web Edition
    Modelsim version is ModelSim ALTERA STARTER EDITION 10.1d
    The dump of the report file is:
    Info: Start Nativelink Simulation process
    Info: NativeLink has detected a mixed Verilog and VHDL design -- none simulation models will be used
    ========= EDA Simulation Settings =====================
    Sim Mode              :  RTL
    Family                :  cycloneive
    Quartus root          :  c:/altera/13.1/quartus/bin64/
    Quartus sim root      :  c:/altera/13.1/quartus/eda/sim_lib
    Simulation Tool       :  modelsim-altera
    Simulation Language   :  none
    Simulation Mode       :  GUI
    Sim Output File       :
    Sim SDF file          :
    Sim dir               :  simulation\modelsim
    Info: Starting NativeLink simulation with ModelSim-Altera software
    Sourced NativeLink script c:/altera/13.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
    Warning: File TestProject1_run_msim_rtl_none.do already exists - backing up current file as TestProject1_run_msim_rtl_none.do.bak1
    NONE
    Error: NativeLink simulation flow was NOT successful
    ================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
    Nativelink TCL script failed with errorCode:  NONE
    Nativelink TCL script failed with errorInfo:  can't read "family_all_lib_list(cycloneive,none)": no such element in array
        while executing
    "set my_lib_list $family_all_lib_list($family,$language)"
        (procedure "::quartus::sim_lib_info::get_sim_models_for_family" line 12)
        invoked from within
    "::quartus::sim_lib_info::get_sim_models_for_family $family $language $rtl_sim $tool $hdl_version"
        (procedure "get_sim_models" line 7)
        invoked from within
    "get_sim_models $family $language $rtl_sim $tool"
        (procedure "get_sim_models_for_design" line 8)
        invoked from within
    "get_sim_models_for_design $lang $rtl_sim "modelsim""
        invoked from within
    "if  {
    	nl_postmsg  error "Error: Can't open file $msim_do_file_name: $file_id"
    	set msim_do_file_n..."
        (procedure "gen_msim_script" line 69)
        invoked from within
    "gen_msim_script args_hash"
        ("eval" body line 1)
        invoked from within
    "eval gen_msim_script args_hash"
        invoked from within
    "if  {
    	error "$::errorCode" "$::errorInfo"
        } elseif {$script_mode == 0} {
    	post_message..."
        (procedure "launch_sim" line 109)
        invoked from within
    "launch_sim launch_args_hash"
        invoked from within
    "eval launch_sim launch_args_hash"
        invoked from within
    "if  {
    				set savedCode $::errorCode
    				set savedInfo $::errorInfo
    				error $result $savedInfo $savedCode
    			} else {
        invoked from within
    "if  {
    			set status 1
    			if  {
    				set sav..."
        (procedure "run_sim" line 78)
        invoked from within
    "run_sim run_sim_args_hash"
        invoked from within
    "if  {
    			error "$result" $savedInfo $savedCode
    		} else {
    			er..."
        (procedure "run_eda_simulation_tool" line 330)
        invoked from within
    "run_eda_simulation_tool eda_opts_hash"
    Thanks!
    It seems the important message is:
    A report of a simulation I done is:
    Info: NativeLink has detected VHDL design -- vhdl simulation models will be used
    Some reports on the Web, show mixed Verilog and VHDL design, but says "vhdl simulation models will be used" instead. Did you use vhdl and verilog codes?
    No. My files are only one VHDL file, one translated-to-VHDL .bdf file and a PLL from ALTERA library
    I created another project i included the same files and it runs. Until the next time it fails again. Is it a bug of 13.1?
    I had similar error with 13.1 build 162 web edition:
    after a clean install, i got stuck with:
    [modelsim.ini addsubsum_nativelink_simulation.rpt]
    Error: Can't launch the ModelSim-Altera software -- the path to the location of the executables for the ModelSim-Altera software were not specified or the executables were not found at specified path.
    Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option.
    my EDA Tool path for ModelSim-Altera is and was by default set to c:\altera\13.1\modelsim_ase\win32aloem
    Resolved it by copying c:\altera\13.1\modelsim_ase\modelsim.ini --> c:\altera\13.1\modelsim_ase\win32aloem
