12 years agoHi!
I am using Quartus II 64-bit version 13.1.0 Build 162 10/23/2013 SJ Web Edition Modelsim version is ModelSim ALTERA STARTER EDITION 10.1d The dump of the report file is:
Info: Start Nativelink Simulation process
Info: NativeLink has detected a mixed Verilog and VHDL design -- none simulation models will be used
========= EDA Simulation Settings =====================
Sim Mode : RTL
Family : cycloneive
Quartus root : c:/altera/13.1/quartus/bin64/
Quartus sim root : c:/altera/13.1/quartus/eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : none
Simulation Mode : GUI
Sim Output File :
Sim SDF file :
Sim dir : simulation\modelsim
Info: Starting NativeLink simulation with ModelSim-Altera software
Sourced NativeLink script c:/altera/13.1/quartus/common/tcl/internal/nativelink/modelsim.tcl
Warning: File TestProject1_run_msim_rtl_none.do already exists - backing up current file as TestProject1_run_msim_rtl_none.do.bak1
NONE
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: NONE
Nativelink TCL script failed with errorInfo: can't read "family_all_lib_list(cycloneive,none)": no such element in array
while executing
"set my_lib_list $family_all_lib_list($family,$language)"
(procedure "::quartus::sim_lib_info::get_sim_models_for_family" line 12)
invoked from within
"::quartus::sim_lib_info::get_sim_models_for_family $family $language $rtl_sim $tool $hdl_version"
(procedure "get_sim_models" line 7)
invoked from within
"get_sim_models $family $language $rtl_sim $tool"
(procedure "get_sim_models_for_design" line 8)
invoked from within
"get_sim_models_for_design $lang $rtl_sim "modelsim""
invoked from within
"if {
nl_postmsg error "Error: Can't open file $msim_do_file_name: $file_id"
set msim_do_file_n..."
(procedure "gen_msim_script" line 69)
invoked from within
"gen_msim_script args_hash"
("eval" body line 1)
invoked from within
"eval gen_msim_script args_hash"
invoked from within
"if {
error "$::errorCode" "$::errorInfo"
} elseif {$script_mode == 0} {
post_message..."
(procedure "launch_sim" line 109)
invoked from within
"launch_sim launch_args_hash"
invoked from within
"eval launch_sim launch_args_hash"
invoked from within
"if {
set savedCode $::errorCode
set savedInfo $::errorInfo
error $result $savedInfo $savedCode
} else {
invoked from within
"if {
set status 1
if {
set sav..."
(procedure "run_sim" line 78)
invoked from within
"run_sim run_sim_args_hash"
invoked from within
"if {
error "$result" $savedInfo $savedCode
} else {
er..."
(procedure "run_eda_simulation_tool" line 330)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
Thanks!
