13 years agoWhen you run 'aocl install' make sure to do so as root/administrator. Also, the flash programming occurs usually over USB-Blaster, so even without a valid PCIe device or interface you should be able to perform this step. Are you sure that the USB-Blaster cables have been attached correctly?
Also, it is recommended that you use 'aocl flash <image>.aocx' rather than using the quartus programmer directly. After flashing the device with a 13.0 aocx image and installing the proper PCIe driver, the device ID with lspci should be 0xAB00.
