11 years ago
Multiplication by constant
Hi all. Just found out that Quartus does not instantiate hard block multiplier if multiplication is done by a constant. Even if i define multstyle = "dsp", why?
    --- Quote Start ---
    --- Quote End ---
    what value is your constant?
    With a constant there are some sizable reductions that can be done during synthesis to make it more palatable in logic. That being said, if you have a DSP block available, why not use it. Perhaps try keeping the constant, e.g.
    (* keep *) wire mult_const;
    assign mult_const = 16'ha9a9;
    I'm guessing something like that will get it to synthesize a DSP.
    If the constant value is 2^n, then the result is simply a bitshift.
    Similarly, if it has just a couple of bits set, it may be easier just to create an adder.
    Thanx for fast reply, however it was a simple typo, so now synthesis multstyle works fine :). So not to create one more thread, ill ask here, for example i need to partially connect some modules output (let it be 8 most significant bits of 16). The straightforward solution is:
    mult mult_inst(
      .a(a_8bit),
      .b(b_8bit),
      .res(c_16bit)
    assign c_8bit = c_16bit
    May there be more elegant approach (without this intermediate wire) ?
