11 years agoMultiplexer testbed simulation/ Quartus II 13.0 64 bit????
Hello there,
I am currently trying to run a testbed simulation of a multiplexer using Quartus II 13.0 64 bit, I followed all the procedures to generate waveforms in conjunction with ModelSim-Altera but there seemed to be a problem with my code. It says: Error (10482): VHDL error at tb_NAME.vhd(83): object "a" is used but not declared Here is my full code: Vhdl Test Bench template for design : NAME -- -- Simulation tool : ModelSim-Altera (VHDL) -- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY NAME_vhd_tst IS END NAME_vhd_tst; ARCHITECTURE NAME_arch OF NAME_vhd_tst IS -- constants -- signals SIGNAL d0 : STD_LOGIC; SIGNAL d1 : STD_LOGIC; SIGNAL d2 : STD_LOGIC; SIGNAL d3 : STD_LOGIC; SIGNAL f : STD_LOGIC; SIGNAL s0 : STD_LOGIC; SIGNAL s1 : STD_LOGIC; COMPONENT NAME PORT ( d0 : IN STD_LOGIC; d1 : IN STD_LOGIC; d2 : IN STD_LOGIC; d3 : IN STD_LOGIC; f : OUT STD_LOGIC; s0 : IN STD_LOGIC; s1 : IN STD_LOGIC ); END COMPONENT; BEGIN i1 : NAME PORT MAP ( -- list connections between master ports and signals d0 => d0, d1 => d1, d2 => d2, d3 => d3, f => f, s0 => s0, s1 => s1 ); init : PROCESS -- variable declarations BEGIN -- code that executes only once WAIT; END PROCESS init; always : PROCESS -- optional sensitivity list -- ( ) -- variable declarations BEGIN -- code executes for every event on sensitivity list a<='0'; b<='0'; wait for 50ns; a<='1'; b<='0'; wait for 50ns; a<='0'; b<='1'; wait for 50ns; a<='1'; b<='1'; wait for 50ns; a<='0'; b<='0'; wait for 50ns; WAIT; END PROCESS always; BTW, understand I have to declare variable, I'm just not sure how!!! Tanks in advance END NAME_arch;
