9 years agoMultiple RAM with different mif file
Hi all, I am doing a project to design 128 processors with a RAM in each processor. Every thing is the same but the initial data in the RAM. The design of the RAM is using the on chip memory. I...
9 years agoThank you for your help!
I am not sure if I understand this fully. Correct me if I am wrong. Suppose these 128 RAMs are all true dual port RAM. Then the set up for a True Dual Port RAM in altsyncram will be something look like following
altsyncram_component : altsyncram
GENERIC MAP (
address_reg_b => "CLOCK0",
clock_enable_input_a => "BYPASS",
clock_enable_input_b => "BYPASS",
clock_enable_output_a => "BYPASS",
clock_enable_output_b => "BYPASS",
indata_reg_b => "CLOCK0",
-- init_file => "init_data_1.mif", -- this line state the initial file of the ram
intended_device_family => "Stratix V",
lpm_type => "altsyncram",
numwords_a => 128,
numwords_b => 128,
operation_mode => "BIDIR_DUAL_PORT",
outdata_aclr_a => "NONE",
outdata_aclr_b => "NONE",
outdata_reg_a => "CLOCK0",
outdata_reg_b => "CLOCK0",
power_up_uninitialized => "FALSE",
ram_block_type => "M20K",
read_during_write_mode_mixed_ports => "DONT_CARE",
read_during_write_mode_port_a => "NEW_DATA_NO_NBE_READ",
read_during_write_mode_port_b => "NEW_DATA_NO_NBE_READ",
widthad_a => 7,
widthad_b => 7,
width_a => 32,
width_b => 32,
width_byteena_a => 1,
width_byteena_b => 1,
wrcontrol_wraddress_reg_b => "CLOCK0"
PORT MAP (
address_a => address_a,
address_b => address_b,
clock0 => clock,
data_a => data_a,
data_b => data_b,
rden_a => rden_a,
rden_b => rden_b,
wren_a => wren_a,
wren_b => wren_b,
q_a => sub_wire0,
q_b => sub_wire1
If I want to make these map each ram to it I need to do something like
RAM_1 : altsyncram
GENERIC MAP (
PORT MAP (
-- ports mapping
Is that what you mean? And I am not sure how to use loop to finish this. Since in my design, the top level module will be 128 processor connected together, and the RAM is located in each processor module. (Which I think is the lower level module). And this leads to my Question 2 in the main post. Since each processor is the identical but the initial data of the ram, what is the better way to make it? One entity with multiple architectures? Thanks again for your help.
