17 years agoYes Jake that is right, your understanding seems fine..
Hmm your right i don't really init var_switch, but i guess it automatically becomes 0 when the state switches to Start buffering. Yes Depending on Framebuffer_reg i determine which mode to be in. and if mode has not changed i continue toggling between Idle and start buffering. Yes Triggerd state is just to disable the sig_Start_Read sig_Start_Write And yes the Source module gives Data_Read_Complete signal only after both fields are read. nadeem
