17 years ago1 - Could be an addressing problem on your part. Are you perhaps incrementing your address by larger amounts than you expect? This might make the first frame buffer run into the second but not vice-versa.
2 - Have you simulated? 3 - I also have a frame buffer that supports bursting and the Altera VIP packets so I have some experience in the matter. If you don't object to posting your code, I could glance at yours and see if anything obvious jumps out. Jake
