16 years agoThe hold multicycle looks too relaxed. Change the hold multicycle value to 3 and see if you get a hold violation.
Hold multicycle values in SDC start at 0 (the default hold check), which is usually one clock edge before the setup's latching edge. Therefore, to perform a hold check against the launching edge (i.e., a hold relationship of zero), use the setup multicycle value minus 1.
