13 years ago
Multi source?
Hello.
I am trying to make a mac component. Everything is fine, until I put acc (my accumulator) receiving the output value.
The strange thing is that Quartus sythetize it, but Modelsim acuse a multi-source and responde with X in output value.
Do you guys have any ideas?
Here is the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
ENTITY main IS
generic (
size : integer := 4;
port (
clk : in std_logic;
rst : in std_logic;
a_i : in std_logic_vector(size-1 downto 0);
b_i : in std_logic_vector(size-1 downto 0);
out_o : out std_logic_vector(2*size-1 downto 0)
END main;
ARCHITECTURE bhv OF main IS
COMPONENT mac
generic (
width : integer);
port (
clk : in std_logic;
rst : in std_logic;
a_i : in std_logic_vector(width-1 downto 0);
b_i : in std_logic_vector(width-1 downto 0);
acc : in std_logic_vector(2*width-1 downto 0);
out_sig : out std_logic_vector(2*width-1 downto 0)
END COMPONENT;
signal acc, out_sig, out_acc : std_logic_vector(2*size-1 downto 0) := (others => '0');
BEGIN
mac1: mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_sig);
reg_out : process(clk, rst)
begin
if rst = '1' then
out_o <= (others => '0');
elsif clk'event and clk = '1' then
out_o <= out_sig;
end if;
end process;
reg_acc : process(clk, rst)
begin
if rst = '1' then
acc <= (others => '0');
acc <= out_sig;
end if;
end process;
END bhv;
    Try to replace this line
    mac1 : mac GENERIC MAP (size) PORT MAP (clk, rst, a_i, b_i, acc, out_sig);
    With this
    mac1 : mac
            GENERIC MAP (
                width => size
            PORT MAP (
                clk     => clk,
                rst     => rst,
                a_i     => a_i,
                b_i     => b_i,
                acc     => acc,
                out_sig => out_sig
    If the entity of "mac" has a different signal order then your component declaration you avoid problems with explicitly mapping each signal this way.
    I think you should set your reset signal to a defined state in your testbench, currently it is undefined.
    In the signal declaration you assign (OTHERS => '0') to "out_sig" try to replace your signal declaration:
         SIGNAL acc, out_sig, out_acc : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
    with this code:
        SIGNAL acc     : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
        SIGNAL out_acc : std_logic_vector(2*size-1 DOWNTO 0) := (OTHERS => '0');
        SIGNAL out_sig : std_logic_vector(2*size-1 DOWNTO 0);
    Currently I only can make an educated guess on behalf of your error description what may be wrong with your VHDL code.
    The best way would be if I can replicate the problem on my side, but for this I would need the code your "mac" component and your testbench.
