11 years agomSGDMA: Incorrect operation but the behavior changes when SignalTapII is inserted.
Hi all, Please help me. I am using two mSGDMA modules to read and write DDR3 on DE5-NET board with quartus ii ver 14.1.1. The mSGDMA is of the modules of Qsys ver 14.1. The problem that ...
11 years ago --- Quote Start --- 8. The mm-master of msgdma_ur1 and msgdma_uw1 is of a 512-bit width @ 150mhz. They each have configurations of burst length is 0x20 command FIFO depth 128 descriptor FIFO depth 128 --- Quote End --- When I disabled the burst transfer, then the mSGDMAs work completely. However, the DDR3 memory throughput gets very low. I need burst transfer. For max burst count = 2, 8, and 64, the mSGDMA modules have the same failure as that for max burst count = 32. Mickycat
