12 years agomotor speed variable using FPGA
Hi. How to design variable speed motor using FPGA. I want to design line follower robot in different surface application for example, on roughness(slow) or smooth floor(fast).
What kind of motor? (stepper, DC, ....)
What kind of control for motor driver? (pulse, pwm, analog, ... ) - Altera_Forum
--- Quote Start --- What kind of motor? (stepper, DC, ....) What kind of control for motor driver? (pulse, pwm, analog, ... ) --- Quote End --- Hi Cris72, I plan to use DC motor and pwm as a driver. Can u give an idea? - Altera_Forum
If you are only supposed to generate a pwm signal for open loop drive control, it's an easy task with fpga.
You basically need a counter+comparator and possibly some extra logic for setting the pwm level. Whiile if you want a complete closed loop controller, your system must provide some sort of feedback signals in order to adjust the pwm level in real-time. - Altera_Forum
--- Quote Start --- If you are only supposed to generate a pwm signal for open loop drive control, it's an easy task with fpga. You basically need a counter+comparator and possibly some extra logic for setting the pwm level. Whiile if you want a complete closed loop controller, your system must provide some sort of feedback signals in order to adjust the pwm level in real-time. --- Quote End --- I have some different opinion about this. If the stepper motor controler is supposed with PWM,the stepper motor's speed is relation with the pwm's frequency.That is to say,if I want to get the variable stepper motor speed,I should get variable frequency of pwm. If the input frequency of FPGA is 50MHz,using the counter++,may get those frequency,like 25MHz,12.5MHz,6.25Mhz,....and so on. But,there is some frequency can no be reached,like 20MHz,or 999999Hz. I do not kown how to deel with this. Do you have any opinion about those? - Altera_Forum
--- Quote Start --- I have some different opinion about this. If the stepper motor controler is supposed with PWM,the stepper motor's speed is relation with the pwm's frequency.That is to say,if I want to get the variable stepper motor speed,I should get variable frequency of pwm. If the input frequency of FPGA is 50MHz,using the counter++,may get those frequency,like 25MHz,12.5MHz,6.25Mhz,....and so on. But,there is some frequency can no be reached,like 20MHz,or 999999Hz. I do not kown how to deel with this. Do you have any opinion about those? --- Quote End --- generate clock enable using modulo accumulator. add your word non-stop. then at overflow generate a pulse The equation for frequency becomes: f = clk speed * accum word value/accum resolution e.g. if accum is 32 bits and word is 2^30 and clock is 50MHz then: f = 50 * 2^30/2^32 = 50/4 Mhz - Altera_Forum
--- Quote Start --- generate clock enable using modulo accumulator. add your word non-stop. then at overflow generate a pulse The equation for frequency becomes: f = clk speed * accum word value/accum resolution e.g. if accum is 32 bits and word is 2^30 and clock is 50MHz then: f = 50 * 2^30/2^32 = 50/4 Mhz --- Quote End --- I konw what you mean. e.g. if accum is 32 bits and word is 2^30 and clock is 50MHz then: f = 50 * 2^30/2^32 = 50/4 Mhz.I can get 12.5Mhz frequency pwm,this is surely. But if I want to get stable frequency of 12.4Mhz,or 12.6MHz,this way can not work. - Altera_Forum
There's another way to generate a frequency with a (almost) continous range.
You must use an adder with an overflow detector. The registered adder output is fed back to one of the inputs, while the second input is a value proportional to the desired frequency. For example, let's suppose a 32bit wide adder, with inputs A and B and output (registered) Q. Let P be the overflow output. You connect Q back to A. At each clock pulse you have Q = Q + B, then the overflow pulse is generated every 2^32 / B clocks. In other words, the frequency of P signal is Fclock x B / 2^32 which can be modulated with a good resolution, provided you don't get too close to Fclock. This is easy, if you only need a frequency synthesizer. Generating the actual pwm could be more tricky, especially if you need an exact duty cycle rather than fixed width pulses, - Altera_Forum
Oops, Sorry. I didn't see you had already got an answer
--- Quote Start --- I konw what you mean. e.g. if accum is 32 bits and word is 2^30 and clock is 50MHz then: f = 50 * 2^30/2^32 = 50/4 Mhz.I can get 12.5Mhz frequency pwm,this is surely. But if I want to get stable frequency of 12.4Mhz,or 12.6MHz,this way can not work. --- Quote End --- you will get any frequency. In many cases the exact pulse frequency wouldn't be as a clean clock but over a window of time it will be correct and for stepper motor it should be more than enough. example 50MHz * 2333456/2^32 = ? Anyway from 50MHz you cannot get exact frequencies except for cases like half/quarter etc unless you use variable analogue PLL - Altera_Forum
--- Quote Start --- There's another way to generate a frequency with a (almost) continous range. You must use an adder with an overflow detector. The registered adder output is fed back to one of the inputs, while the second input is a value proportional to the desired frequency. For example, let's suppose a 32bit wide adder, with inputs A and B and output (registered) Q. Let P be the overflow output. You connect Q back to A. At each clock pulse you have Q = Q + B, then the overflow pulse is generated every 2^32 / B clocks. In other words, the frequency of P signal is Fclock x B / 2^32 which can be modulated with a good resolution, provided you don't get too close to Fclock. This is easy, if you only need a frequency synthesizer. Generating the actual pwm could be more tricky, especially if you need an exact duty cycle rather than fixed width pulses, --- Quote End --- Yes,maybe my expression is wrong. In fact,I need generate fixed width pulses. Your reply seems feasible.I will try it.
