13 years agomotor speed variable using FPGA
Hi. How to design variable speed motor using FPGA. I want to design line follower robot in different surface application for example, on roughness(slow) or smooth floor(fast).
8 years agoThere's another way to generate a frequency with a (almost) continous range.
You must use an adder with an overflow detector. The registered adder output is fed back to one of the inputs, while the second input is a value proportional to the desired frequency. For example, let's suppose a 32bit wide adder, with inputs A and B and output (registered) Q. Let P be the overflow output. You connect Q back to A. At each clock pulse you have Q = Q + B, then the overflow pulse is generated every 2^32 / B clocks. In other words, the frequency of P signal is Fclock x B / 2^32 which can be modulated with a good resolution, provided you don't get too close to Fclock. This is easy, if you only need a frequency synthesizer. Generating the actual pwm could be more tricky, especially if you need an exact duty cycle rather than fixed width pulses,
